Strange rear light lens?
Posted: Fri Mar 10, 2006 6:34 pm
by Finnpaso
Can anybody explane thiskind rear light lens, what is in ebay now:
http://cgi.ebay.com/ebaymotors/Ducati-P ... 6422QQrdZ1
I have never seen such :confused: It looks totally different, than "Euro modell". I havent ever seen inside things of USA modell, so is this connected some way to USA rear light ??? or......what? Seems, that i have still some things to learn about Pasos :laugh:
Posted: Fri Mar 10, 2006 7:36 pm
by DesmoDog
Looks like your typical USA spec Paso tail light to me...
Posted: Fri Mar 10, 2006 7:55 pm
by Finnpaso
I am 110% sure, that USA modell "all red" lens is just samekind, as EU modell, with yellow blinkers, cause i have changed such just with one Florida guy from this Ducatipaso.org site, and i have both modells now, but this in ebay looks totally different! Look carefully, especially lower part of lens. .... or am i totally sick? It can also be so, cause i have been in hard flu now about 2 weeks :mad:
Posted: Sat Mar 11, 2006 10:15 pm
by 750pheonix
Finnpaso, that is the identical shape to the Euro shaped lense... the shallow red thing at the bottom houses the clear plastic used to illuminate the number plate.
hope the flu gets better... VitC halves it's duration btw.
Posted: Sun Mar 12, 2006 3:23 pm
by Finnpaso
It CAN be, that i have too much fever still ! But looks little different that rear light/brake part of lens (higher).... Btw, i have seen in internet long time ago some samekind lens in some Paso "prototype", or something, like that. That came to my mind just.... anyway, this is not so important, but i only noticed, that center part of lens is higher, than normal Paso lens.... :confused: I am virgin, so all thiskind things burn my brains very much :laugh:
Posted: Mon Mar 13, 2006 1:11 am
by Marinus
You are quite right Antti.
That would not fit my bike as the top of mine is flat not raised like that one. I do need one though as mine is rather beat up. I have an all red one (USA) however in NZ we’re meant to have orange indicators.
Having another look at it the raised bit in the middle may fit under the back locker and would not be visible once on the bike.
Posted: Mon Mar 13, 2006 6:51 am
by 750pheonix
Posted: Mon Mar 13, 2006 9:13 am
by Marinus
That is a very nice tail light. I wish mine was in such good shape. It is made by CEV the same as the front indicators. Is yours the same brand?
Posted: Tue Mar 14, 2006 7:15 pm
by Finnpaso
750pheonix! Yours is NORMAL EUROPE tailight!!! NOT any "protype", what seems to be higher. U have normal.... 110% sure of it! EXACT same, as USA, what have red blinker parts. ALSO THOSE BOTH HAVE EXACT SAME manufacturing numbers stamped to lens!!! I know, cause i have both modells. :D
Posted: Tue Mar 14, 2006 8:37 pm
by Marinus
So why is it that the front indicators are easy to get and the rear are not?
Dose CEV still make the front ones or did they just make so many that there is a stock pile somewhere?
How much demand is there out there for the back lenses?
Posted: Wed Mar 15, 2006 7:51 am
by Finnpaso
Seems, that Ducati have still, or make still those front blinker lenses, but very many USA guys want to change "all red"Usa modell rear taillight lens to Euro modell with yellow blinkers, that they can get rid of those awfull looking rear turn signals(and put bulb holdwers inside taillight).... Pasos styling is designed with ONLY blinkers integrated to rear light system :thumbup:
Posted: Wed Mar 15, 2006 8:12 am
by Marinus
I have an all red tail light but the blinkers are in it. I waould also like orange blinkers. The internals are all set up just got the wrong lense.
Posted: Wed Mar 15, 2006 7:02 pm
by Finnpaso
There are (at least)2 different rear lights, those with blinkers(EU modell) and without inside blinkers(USA modell) and fitting to lens is totally same, so "You" can change lenses easily, without any modifications.
As normally, we Europeans want "USA all red" lens, cause its quite rare here and surely You want with yellow blinkers, cause its rare there in NZ and Australia. Both lenses have same totally same numbers stamped, so easy to change lenses, BUT "your" country rules makes, WHAT is legal and what is not legal. Here in Finland many USA cars imported to Finland have red blinkers, and they say, that its ok, if "all red" blinkers have those "EU needed numbers"(like Paso lens have luckily!!!), but surely it depends about local rules... and here polices seem to NOT have enough time to check such things in traffic, so i think, no any broblem here to use all red Usa style lens in Paso. But better fist check thing about local rules :thumbup:
Btw, i changed just my "Euro lens" to "USA lens" with one guy here in this site...
