Parts Manual / Part numbers help
Posted: Wed Apr 05, 2006 11:07 pm
At my local Ducati dealer they do not have an up to date 750 Paso Microfiche (they do have a 906 fiche). I can print the pages or at least write the part numbers down that are needed (and they are quite accomidatiing in ordering the parts). The problem I am having is that it appears that the mircrofiche that we have on our downloads section has the "old" part numbering system and Ducati has changed all of the part numbers to a new numbering system. I specifically need the up to date part number for the oil line that runs from the bottom port of the engine to the T between the lower radiator ports. On the fiche that we have this is listed as part # 037093140, item #3, identified as a pipe, on TAV 15. Is there a simple way to convert this to the new numbers? Can anyone supply me with the correct number for this hose?
Thanks,
Doug
Thanks,
Doug
