It is currently Sun May 09, 2021 10:34 am
 Post subject: Fan thermo sensor/switch
PostPosted: Tue May 04, 2021 12:21 am
Apparently my fan thermo switch is bad. Does anyone know of a replacement for the sensor/switch ? I've read that it's a common sensor/switch. But I am having a hard time finding one that is a correct fit. Of course I can always run a bypass switch but I'd rather use a workable thermo switch. Thank you!
 Post subject: Re: Fan thermo sensor/switch
PostPosted: Tue May 04, 2021 9:09 am
That thermo switch was used on the 906, 907ie, 851, 888 and 9176 and early 748 but is no longer available.
https://www.stein-dinse.biz/product_info.php?products_id=114492
However the switch for the later 748 and the 996 is available. It is essentially the same switch but with a different connector. It would need the connector of the 907 loom changed to fit.
https://www.stein-dinse.biz/advanced_search_result.php?inc_subcat=1&keywords=55240081A&x=0&y=0&categories_id=
PostPosted: Thu May 06, 2021 4:48 pm
A lot of this type of part was also common on cars. Isn't there a site or posting of common parts that where also used on cars at the time? Maybe it's on that list.
Users browsing this forum: Google [Bot] and 15 guests
