Now i have normal cast iron original 280mm rotors with adapters to 4 piston black Brembos, but planning in future 17" conversion with same calipers to original M1R fork, but with 17" wheel and 320mm rotors.
All info will be welcome
![:thumbup: :thumbup:](./images/smilies/thumbsup.gif)
Here there is the conversion to 320 mm. rotors, 40 mm. calipers (Brembos black or earlier goldline) keeping the 16" wheels.Finnpaso wrote:Yes, i meant adopters between 320mm normal Ducati rotors / 4 piston Black Brembos(or early "golden line" Brembos) / original 750 M21R fork.
Yes, it's right, I was mistaking.ansim wrote:Nope, it's still the 280mm rotors and 16" wheel.
Check these pictures, http://www.geocities.com/750paso/paso/4 ... sult12.htm
But it is not so tight with 40mm spacing calipers.
