Got the bike for... $1250. Anyone in Indianapolis familiar with these 'cause I could use an experienced hand.
-Dana
Cursed Paso
- Skins
Re: Cursed Paso
Well done! Good luck!
Dana
Re: Cursed Paso
Thanks!
There HAS to be, somewhere in Indy, a Duc mechanic who is NOT A DEALER!
- Fraser
- year: 1986
Re: Cursed Paso
Well done Dana, best of luck with your new acquisition, look forward to assisting with any problems.
Fraser.
Fraser.
Dana
Re: Cursed Paso
I think the first step will be to pull the fuel tank and empty it (into an approved DOT container), check out the insides, clean out any old leaves and such (lol). I have heard that with Dellortos a fuel pump is not needed. Is that a general consensus?Fraser wrote:Well done Dana, best of luck with your new acquisition, look forward to assisting with any problems.
Fraser.
I mean, we didn't need fuel pumps on the old bevelhead bikes with 40mm carbs. Not sure why the frell they went with a single Weber in the first place. Anyway, once I get the tank off I'll post pix and I can get feedback on the angles the carbs are mounted at and all that jazz.
Wooo. Two malfunctioning Ducs in one house. Can the world get any better?
- Finnpaso
- year: 0
Re: Cursed Paso
Yes, it can be...... with 5 Ducatis!Dana wrote: Can the world get any better?
Anyway, if U find some rust from tank, its not so bad idea to cover inside with POR 15 system. I did that to my 750 Paso fuel tank and i am 100% satisfied
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- Skins
Re: Cursed Paso
If you have 36mm DelOrtos on your Paso, you definitely do not need a fuel pump, and with careful carburetor balance and tuning, you will be able to get wonderfully smooth power throughout the rev range. My 750 was running smoothly at only 2500 rpm in fifth the other day, slightly downhill.
- jcslocum
Re: Cursed Paso
Skins,Skins wrote:My 750 was running smoothly at only 2500 rpm in fifth the other day, slightly downhill.
We have 100% trust and faith in you!! This comment though is bordering on hyperbole. Must have been steeply down hill :-)
- Skins
Re: Cursed Paso
Fact, mate, I swear. She runs bloody great anyway, but that was the best I've ever seen. Slightly downhill, just a whiff of throttle ...
I put it down to carefully organised throttle cables and my 'Ducati Cuddle' technique. Last time I checked my slides (about 1000 miles ago) their movements could not be separated.
- jcslocum
Re: Cursed Paso
I beleive you mate! The cuddle is the way to go.
