let me know
906 engine wanted!!!
guys as i wrote in ter title i'm looking for a 906 engine, cause i found a used 750 engine but with the bike stuck i'm thinkin about an hp upgrade....
let me know
let me know
Re: 906 engine wanted!!!
the little more power goes lost with the higher weight
- persempre907
Put an 851/888 engine!!! It will fit well on the Paso framepaso750 wrote:the little more power goes lost with the higher weight
- ducapaso
Both of these solution require a water cooling plant... Yuo ever realized that Elefant engines are still air cooled?persempre907 wrote:Put an 851/888 engine!!! It will fit well on the Paso framepaso750 wrote:the little more power goes lost with the higher weight![]()
If you need an extra money effort, you can install a dry clutch on such an unit...
ex...Red "smooth" 753349
- Finnpaso
- year: 0
Its not so easy to find good condition injected Elefant 900cc engine....
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
so for you it's better the 750 engine instead of the 906.....mmmm good to know, in a first moment i was looking for a 900 monster engine but i'm scared by the long list of modifies to the case and to the electronic ...
hope to give you notice soon...
lamps
Piero
lamps
Piero
- englishstiv
Not that it's any use to know now but a full 906 motor just sold on the British ebay for £100.00. If I had known it was gonna be that cheap I would of bid myself. what a bumma
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
