Nutshell: a week ago I got T-boned on my Monster, commuting to work. A Hyundai SUV went straight through a turn-only lane and broadsided me, throwing me down the street and pinning the Monster. I walked away w/ rashed legs, nothing broken - but the Monster is pretty busted (both footpeg brackets, bent exhaust plumbing, snapped the RT side clip-on, turn signals, and various other maladies). So now, not only do I have room in the garage to work, but a reason & opportunity.
I've begun to tear down the Paso to get to what needs doing. I've pulled the rear shock and I'm sending that down to Steve @ ECS to get overhauled; I'll be pulling the forks shortly to get refreshed as well. I have a pair of Mikuni 38s I'd like to put on, but taking a closer look at the tubing and hoses - with fresh eyes, since it's been so long since I've spent any quality time under her skin - I got wondering about a couple things. So I'm posting here for your opinions & suggestions ...
I realize the following items change the nature of the Paso, but I'm just putting them out there for someone to talk me into - or out of - them ...
1. Case breather hoses
Since I'm planning to get rid of the Weber (and its airbox), I'm looking at the case I have a crank case breather assembly, where one hose exits the case (behind the vertical cylinder) into a small collector box (behind the tank, in front of the battery), and then a second hose goes up to the front of the airbox. I have a crank case breather from Evoluzionne - I may install this instead. Any thoughts on this?
2. Oil coolers & lines
I'm wondering about replacing the dual coolers w/ a single, valve cover-mounted unit from the Monster/SS models. I'd have to replace the horizontal cylinder cover with a Monster/SS unit (that has the hangers), and I'd probably opt for the high-mounted cooler for clearance reasons. But is there any reason to do, or not to do this kind of modification? [At the same time, I might also see about fabbing up some sort of channel that will feed air through the now-open side vents (with the 2 oil coolers removed) and direct fresh air onto the vertical cylinder.]
If I decide to keep things stock, can anyone recommend any preferred brands/vendors/upgrades or alternatives for the oil lines?
Right now, on my must-have list of things to do:
- Refreshed suspension
- New fuel lines (and filter)
- S/S braided brake lines
- Brake pads
- Case breather
- Oil lines/cooler swap
- Mikuni conversion
- The jcslocum electrical upgrade
Oh yeah ... what have I missed?
