Hello everybody,
I need heed your help, I just picked up a 1988 Paso
The motor turns over but it wont start. I checked it seems to have spark and compression, it has been sitting for a couple of years the fuel pump is working and I tried starting fluid and it seemed to cough one time.
Any ideas? I am going to pull the tank and see if if I can get anywhere by checking out the carb.
Jeff
1988 Paso wont start
socaljeff3798
- year: 1986
- ducapaso
Re: 1988 Paso wont start
If you pull the tank off, first of all, try to put some drop of fuel (just 2 or 3) in the throttles and start:
You'll soon know if it's a carb trouble
ex...Red "smooth" 753349
socaljeff3798
- year: 1986
Thanks Nicola,
I am going to try that in the morning
Jeff
Jeff
Even though it`s tempting do not start the bike! If it sat for years change the belts first. What you do is risking an engine damage.
Then drain all the old fuel from tank, carbs and lines and fill it up with fresh fuel. It may be that your carbs need cleaning, too as old fuel can cause sediments on the carb specially the float chamber.
- ducapaso
Of course!.paso750 wrote:Even though it`s tempting do not start the bike! If it sat for years change the belts first. What you do is risking an engine damage.
Timing belts every second year!
