Flasher switch?
yatzee
Flasher switch?
Post by yatzee »
Hi guys
The flasher switch (for the directional lights) mysterious broke and i need to find a replacement.
I have ebay searches going, but no luck so far. Does a switch from any other model of Ducati fit?
Thanks in advance.
Re: Flasher switch?
You mean the handlebar switch ? The whole assy is the same on all Paso, Sports, early Supersports and if I remember well also 851/888. Later models may look the same but have different type connectors.
If you`re good soldering it`s no problem to replace the connector of a newer handlebar switch assy with your old connector.
This one`s in the UK
http://www.ebay.com/itm/Ducati-Left-Han ... 1c25146d7d
persempre907
Re: Flasher switch?
Post by persempre907 »
I can confirm 851 & 888 have got the same left switch.
And it's so: depending by the model the connector can be different.
Derek
Re: Flasher switch?
Post by Derek »
The Supersports up until 1997 are also the same.
yatzee
Re: Flasher switch?
Post by yatzee »
thanks for the information - i wil expand my search!
