Not quite finished yet but is now charging properly with dual headlights on.
Still need to route a few more wires through the new fusebox to get them off the battery and decide where I want to put the regulator permanently but it works
Took the lithium out in favor of a glassmat while I am experimenting, lithium is kind of particular on charge rates
Updating the voltage regulator
Re: Updating the voltage regulator,almost done
- year: 1993
Very interested replicating what the original poster has done as I've a Mosfet Rec knocking around a box of bits in the garage. I've been running HIDs for a couple of years and they are great in terms of being able to see things coming towards you. I may be asking questions in the not too distant future about the installation.
Was the connector issue one of the bullet terminals up by the steering forks? I'm struggling with an underperforming charging system, no charge at idle, about 13 V at 2500. All bullet connectors for the reg. seem to be OK.
