...couldn't be helped.
Saw an ad for a 1990 750 Sport near me for... not much money. So I sent a flurry of messages throughout the day and made him stay up past bedtime to meet me.
Owner had purchased the bike in 2000 - already outfitted with 36mm pumper Dellorto setup, some familiar wiring mods and Ferracci mufflers (!) - and other than some dust and road grime, it was very clean. He said that it had a bent valve - but somehow ran - and that it just bogged under acceleration. I'm no rocket scientist, but I didn't think all of those things could be true at the same time. We tinkered on it past 10pm in his garage, seems the 2nd cylinder cam was off a tooth - but he admitted he had 'played with the timing belts' before he listed it. Thankfully we didn't use the starter to test immediately! I got it timed correctly, and was eventually able to turn it all the way through with the rear wheel. I borrowed a battery to try the starter and both cylinders had compression. Anything else I was sure I could figure out, so gave him cash and brought it home.
I host a bike/shop night at my coffee bar in Seattle - we work on bikes and help anyone that needs guidance navigating simple issues. Between serving beers I'll hop into the fray to futz with whichever project is queued up. I INTENDED to go through the top end before attempting a startup, to make sure everything is where it should be, but after a chat with a veteran moto tech, his advice was if there's no interference and compression, just send it. So, I dribbled some fuel down the hose of this beautiful thing and hooked up a battery. A couple cranks and it roared up and calmly settled to an idle. Sounds amazing and I was the coolest guy in the Pacific Northwest for about 5 minutes.
Shortly after this amazing moment, someone bumped a galvanized pipe that was leaning on the wall and it fell right square on the rear seat cowl, cracking it on a very unfortunate corner. I had to walk away and find a quiet place for a few minutes, but otherwise it's been an exciting, if bittersweet 18 hours of ownership.
When everyone left I put in a late night with the bike on the lift. I tested compression - ~115psi in each, though I don't have full confidence in this gauge. Scope just showed heavy carbon on the piston, and maybe a little nick from a valve kiss, but otherwise a very clean combustion chamber with a nice hone on the walls. No real evidence of a catastrophe. Accelerators on the Dellortos spray cleanly and slide action is smooth. A manual came with the bike and there's a sheet stuffed in the back with a running log of maintenance covering the last 25k of its 33k mile life - also detailing accounts of a camping trip he took with his dad where it fell off the sidestand in some dirt, and a lowside incident from some sneaky gravel - which explains the spare fairing that came with it.
I have no idea why the PO thought it had a bent valve, he couldn't give me a real answer about how he came to that diagnosis - overheated, I played with belts, it ran fine, etc. Nice guy, but I suspect his bogging was something else that I may eventually discover and he was just ready to move on. I will check valves and all the systems before doing any more vroom vroom, and there are some maintenance parts on the way - belts, sprockets, chain, battery, oil filter, etc. I will eventually drop the engine and inspect the top end, as it's a nagging thought, but I'm otherwise very happy to report another running, weird Italian in the stable.
Some notes and observations:
- While it has the turning radius of a Cadillac, this thing is incredibly light and easy to move around.
- I didn't realize the connection between the 750 Sport and the Paso. I have a VERY yellow Paso I picked up years ago as it is exactly the kind of ugly, weird, beautiful stepchild moto I'm drawn to. Whereas the Paso is unfortunately in storage and rarely ridden, I'm itching to get the Sport out and I already have a line on some liveried bodywork to give it a spare outfit. Anyone taken theirs to a track day??
- I have the rear inner fender, but PO ran it without. Other than the obvious potential issues, anyone had problems running without it?
- I know I'll find out on first ride, but any feedback on the shift lever placement? The Paso is notoriously awkward shifting, can I expect an improved experience with this younger sibling?
- Yes that's an Elefant in the background, I said I like the weird ones.
/very excited from Seattle.
After its first bath.
I brought home a 750 Sport
holeinthehead
- year: 1986
Re: I brought home a 750 Sport
Paso shouldnt be awkward shifting ....probly need to have a look at the clutch , they gotta be clean , any black marks on the drive plates will make it sticky , but a well sorted gearbox/clutch should be the proverbial hot knife thru butter . Even the chain condition/tension will affect it .
holeinthehead
- year: 1986
Referring to the placement of the shift lever to the sidestand - I'd constantly have to toe the stand down a smidge to get under the lever.Mc tool wrote: ↑Sat Sep 26, 2026 8:53 am Paso shouldnt be awkward shifting ....probly need to have a look at the clutch , they gotta be clean , any black marks on the drive plates will make it sticky , but a well sorted gearbox/clutch should be the proverbial hot knife thru butter . Even the chain condition/tension will affect it .
- Janky59
Hey @holeinthehead, here’s a reference pic of the lever position on my ‘92.
I’m a US size 10 boot, it slips under without touching the kickstand when I shift it seems to me. I’ve not noticed any contact.
I cringed when I read your sentence about the piece of pipe falling over and whacking the seat cowl.
But overall a neat story, good luck.
Current moto stable:
‘21 Beta 390RS
‘18 BMW R1200RT
‘92 Ducati 907ie
‘21 Beta 390RS
‘18 BMW R1200RT
‘92 Ducati 907ie
My 900ss had an oil pressure warning light ... whilst riding every so often Id see a flash of red in my peripheral vision ...down by the dash lights , so quick I could never be exactly sure , couldnt fault the motor , worried about brief loss of oil pressure .....turned out to be me nudging the side stand whilst going for the up shift enough to flash the side stand warning light at me .
Kiwi Rider
Haven't logged on for a while so late to the party but thats a very tidy 750 Sport you got there. Great that it has the Dellorto's on it. Nice write up.
I have had mine at the track but it wasnt running 100% carburation wise so wasn't a fantastic experience. I've got it in the garage for a 17"wheel conversion and a motor sort out at present. It's become a long term project but I'm not stressed about it. It gets done when it gets done. I've just waited 2 months for a valve guide from Italy...
holeinthehead
- year: 1986
OK after getting to know my new friend I have noticed some quirks. Maybe someone can help shed some light on them..?
Intermittent start-up: I don't ride it often, but have noticed it can be extremely easy or extremely difficult to start depending on ___?___.
Lots of cranking, backfiring etc, then just decides to come to life somewhat suddenly as if I hadn't been asking for 5 min. Battery is charged enough to crank starter with gusto, Fuel pump running (I replaced filter) and overflow circulating back to tank. Choke doesn't seem to matter, but often starts when choke is off, and more often than not, backfires more when choke is on.
I have noticed the startup comes as I let OFF the starter button, but even trying to time it right with the crank and letting off button isn't consistent.
AFAIK, previous owner 'did the starter mod' - which I believe I did on my Paso years ago - but God help me if I remember what exactly that is/was. I recall it allows more juice to the starter and results in the fire to happen on button release..?
I did notice I mysteriously lost spark when left to sit for a while, so presumed weak battery, but hard to believe as it cranks well. With a battery jump pack, the spark returned, so I'm willing to believe.
Before I dig into electronics, wondering if it just wants a 105% charged battery all the time.
Yeah , 1st thing to do is to measure the voltage at the ignition module while the starter is cranking over , I willing to bet your only seeing about 9v and the module wont work properly at that . This is evidenced by the fact that it will start as you release the starter button . Somewhere between the battery and the module you have a bad connection in the power feed , this will be there all the time so a volt drop test will pin[point it ,it wont be enough to mess with the module and the engine will run, but as you are cranking the current draw from the starter will pull the battery voltage down past the point where that and the poor connection will add up to enough voltage drop to cause the module to play up .
Battery jump pack will give the battery a hand and the starting current wont drag battery voltage down so far .....module will work .
Get a wiring diagram and follow the power from the battery to the module and test all the connections ...inc the ignition switch itself . I fitted relays to my Paso ( there is a post/image here somewhere ) I probly overkilled it a bit .
The "starter mod " really only sorts the current to the starter , not the rest of the bike .
Starter mod usually means beefier cables to battery and ignition relay.
What does the plugs looks like after idling a bit? Sounds rich according to your description.
