clutch plates from germany
Re: clutch plates from germany
Gerhard is writing that 51A is 35,5mm thick,
it says that in the link you posted, I haven`t measured it as it`s not the correct clutch pack anyway.
desmodave
Post by desmodave »
hellogrish wrote:hello,
I got new clutch pack nr 19020051A (from USA, thanks to Jon :) )
but I`m a little bit confused:
http://www.desmorados.com/shop/catalog/ ... 20051A.pdf
I`v got the same stuff as in this picture,
8 friction plates, 8 plain plates and 1 "one-side" friction plate (BELAGSCHEIBE ;)
Gerhard is writing that 51A is 35,5mm thick, but it seems to be 35,1.
anyway...
in my Paso I had 7 plain plates, 6 friction plates and one belagscheibe
(2 of plain plates have different thickness)
so I put 7 plain, 6 friction and 1 "one-side" friction plate as well.
(starting from plain, and ending with "one-side")
can you confirm that it`s correct?
clutch nr 22A (that is said to be correct kit) is 33,2mm
maybe I`m bad in math :) but I cannot get this thickness from 51A in any way..
51a is AVAILABLE to keep you running! stop searching for parts that keep you off the road THANKS DAVE M for getting me back {bloody plate saga} 51a is a newer pack that fit -2 plates make sure clip is tapped in tight fit but SORTED happy riding! DESMODAVE.
desmodave
Post by desmodave »
anyway...
desmodave
Post by desmodave »
anyway...
