Paso Electronic Ignition
Dean
Post by Dean »
I am trying to get a 750 Paso running that has been sitting for many years. I don't have any spark and suspect the electronic ignition modules. Does anybody have a suggestion for testing the function of these modules that does not require a scope?
Rodney
year: 1986
Post by Rodney »
have you tested the basics ie the spark plugs, the leads for corrosion , the voltage at the coils , the fuel delivery , the earth for corrosion, the fuses , and the pick ups
Rodney
do you know anyone who has a carbed 750/900 Monster or Supersport so you can test with his CDI units ?
ducapaso
Post by ducapaso »
you can have a look to workshop manual for ignition coils testing...
an ignition module failure is quite unusual and this spare part is no more available on ducati original spare list (no more carb engines! :ugh: ) however you might go searching for ducati perforance cdi with sa step one or two upgrade
Dean
Post by Dean »
Thanks to all that replied. I think I may have assumed the coils are OK because they checked fine with my ohm meter. I am now looking to do a better test on the coils.
