NEED PARTS FOR MY 906 BAD!!! PLEASE HELP!
wineliving
Post by wineliving »
Hello to my new friends and Duc lovers. Got a great Paso with the usual details that need completing. I need some parts for my 1990 906 to make it as perfect as possible.
Here is the list:
1. New taillight assembly including lens (it has built in turn signals)
2. Left/Right front turn signal lenses (I'll take the whole assembly)
3. Round mirror (if you have suggestions for replacement, rather than original, I am open.
4. Trim piece that goes under the instrument cluster
5. Front upper fairing (headlight area, aka windscreen)
6. A working clock.
7. Risers would be nice (aftermarket item)
Thank you all in advance for any help and suggestions.
:laugh: :laugh: :laugh: Just very hard pieces to find! :evil:
you will find all tat parts on ebay (sooner ot later).
Guess all parts will be rather used than new and clock will come with whole instrument cluster.
You can have the risers machined if you find a shop (check the downloads link ib the 750 section).
As for the mirror glass:
Damaged glass can be replaced with a chinese copy of a Yamaha trailbike mirror 100mm diameter and glue it in with silicon rubber. It looks exactly the same as new and has the same focus / perception as the original, cost about Au $11:00
gail
Post by gail »
Howdy, Might be a bit late , Trim around/under?.. instrument cluster, if it is merely the surround that contacts fairing inner front, ? I cut a piece of vacuum hose (size to suit) lengthwise on one side and wrapped it onto surround and cut to length, hope this helps, Top marks to "paso750 on the mirror glass. Regards Marty
wineliving
Thanks for some of the advice. Here is an updated list:
1. New taillight assembly including lens (found and purchased-dealer)
2. Left/Right front turn signal lenses (found and purchased-Ebay)
3. Round mirror (if you have suggestions for replacement, rather than original, I am open. (Joan's Fabric .99 cents 4" perfect fit, dealer wanted $40.00 usd)
4. Trim piece that goes under the instrument cluster (may use diamond plate and fabricate piece)
5. Front upper fairing (home repaired job, looks tolerable)
6. A working clock (still hoping)
7. Risers would be nice (going to a machine shop with suggested plans, thank you kindly for that info)
8. New Item: Cooling expension/resorvois tank.
Thanks guys/gals for reading my post and offering suggestions.
