Front Forks Pressure
Posted: Sun May 22, 2005 5:04 pm
by 4away
Could anyone advise me on the air correct pressure to put in the front forks of a 750 paso for best handling.
Thanks,
Al
(4away)
Posted: Sun May 22, 2005 7:55 pm
by Finnpaso
There SHOULD be atmosphere air pressure inside front fork!!!! Never put higher pressure inside from top valves!!!!!
Those top valves are, that U can take pressure out from forks, cause small amount of air flow via "slider bearings" to inside forks and it should NOT BE THERE.
Finnpaso
907IE
750 Paso
Posted: Sun May 22, 2005 11:16 pm
by jcslocum
No air in the forks.
I find that the handling is very sensitive to air pressure in the tires. The front in particular. I'm at 36 in the back and 35 in the front.
Posted: Mon May 23, 2005 2:46 pm
by Christian
The front air pressure could be use for short time race if the fork woud be not enougth hard !
Posted: Mon May 23, 2005 5:50 pm
by fasterdammit
jcslocum wrote:No air in the forks.
Really? On the frame, it specifies different tire pressures - like 37 rear and 34 front or something. I don't remember off the top of my head ... haveta to look & see. That's what I'm running on the Metzler A59s ...
Posted: Mon May 23, 2005 6:05 pm
by jcslocum
Yes, it really does make a difference.....to me. YMMV
