thosecrazy wires!!!
Posted: Mon Aug 15, 2011 4:36 pm
hi fellas! ive been in the garage with the wiring diagram pdf download (thanks whoever great to see better!)
Ive looked and learned that my alternator has two yellow one red to the diagram gree and red.
the connector im talking about in my regs and wires post is the no.6 instrument connector this joins the regulator ok?
since taking off the original two greens are left these are ok because the are joined together(one question answered)
one pink to dash(charge light ?)
now one red from solenoid? can anyone tell me is it a problem ive left it and it doesnt connect to anything now!!! it is in the connector-should i remove it could this be why my batterys are cooking?
ive also found i had a blown fuse the one that is in the upgrade red wire it has made the fuel pump work but i still have no dash lights horn etc-could something else have blown the solenoid maybe?
waiting for reply....desmodve.
p.s sorry i forgot also since taking off the old reg the two green are ok joined but they did also wire up to the regulator too!!! but not now with the rr51 electrex.
