coolant in oil?
Posted: Tue Oct 13, 2015 5:06 am
I am new to the forum. I bought a 1990 907ie this weekend. Been riding Ducati's since '88, but this is my first "paso". I love the styling and it probably has the best seating position (for me) of all Ducati's. (bit of back trouble)
Anyway, I was happy with the bike, but I could not do a good test drive because it was unregistered and uninsured. It had been standing a long time (years) but appeared to be running OK.
On my first real ride (about 10km) two things happened; discovered that throttle response anywhere over 1/4 throttle was nil, and that got worse until I could barely keep it it running. Feels like it is not getting fuel. (plugs look dry, sparks look OK) Prev owner did mention he had replaced or repaired the fuel pomp, so I got a place to start the search for a cure.
The other thing has me worried more, oil level was ok when I left, but afterwards, oil in the sight glass had gone to butter, initially I thought condensation, but after a few hrs it was still butter, no level movement at all in the sight glass. Poked around with a rod in the filler and it came back with butter on it. Also the level in the coolant tank had gone down about 1 cm (I checked and marked it before the ride). I don't dare thinking, but is it possible that coolant is leaking into the engine via the pump shaft or cylinder base? Has anyone seen that happen? Have not had time, but I will drain the oil tonight and check what comes out.
Sorry for the long first post, any info on water in oil appreciated.
cheers J
cheers J
