907IE Fuel Tank Wanted
New or good secondhand 907IE tank wanted. Paint condition not that important but must be rust-free internally.
Thanks.
Thanks.
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
1985 LAVERDA SFC 1000
1993 DUCATI 907IE sold May 2017
1993 DUCATI 907IE sold September 2017
1995 TRIUMPH DAYTONA SUPER III
1980 LAVERDA JOTA
1982 HESKETH V1000
Re: 907IE Fuel Tank Wanted
if the picture is correct the description isn`t and it`s a 907ie tank
http://www.ebay.com/itm/1986-1989-Ducat ... CB&vxp=mtr
Many thanks. I had a good look at the photos. It looks like a 907IE tank from above but the base and connections are quite different to my bike and looks like it is for a carburetor bike - 906 / 750 - and not for injection ? ? ? ? ?paso750 wrote:if the picture is correct the description isn`t and it`s a 907ie tank
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
1980 LAVERDA JOTA
1982 HESKETH V1000
If that is indeed a 750/906 tank I don`t understand why it has the 907ie design, specially as it is new and unused.
But then maybe it was a late friday afternoon and someone in the factory didn`t pay attention ...
Have you tried to send an email to Rudy?
- englishstiv
That is defo' a 907ie tank if you read the description there is some outer cardboard panels sprayed over on the underside that hide the other relevant apertures. That would not fit a 906 or 750 unless you adjusted the Petcock attachment for the fuel supply.
sadly even at £260 with the 50% discount it's a whole lotta money for a fuel tank.
DUCATI 907ie 1992
there`s one picture taken through the filler hole. That on the right is the mount for the electric fuel pump.
The description confuses me a bit. Maybe there were different 907ie gas tanks.
http://forums.ducatipaso.org/viewtopic. ... nside+tank
Many thanks. 260 quid is a lot of money but as my existing one is rotten then I'm running out of options. As the fork stanchions are going to take a while then I shall wait to see if another comes up...englishstiv wrote:That is defo' a 907ie tank if you read the description there is some outer cardboard panels sprayed over on the underside that hide the other relevant apertures. That would not fit a 906 or 750 unless you adjusted the Petcock attachment for the fuel supply.
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
1980 LAVERDA JOTA
1982 HESKETH V1000
The shot through the fuel cap hole shows a very limited view of the fuel pump mount, and the clips where the degasser sits too.
The shot of the bottom of the tank is a bit odd, or I may have missed it. The return line is there, the hole for the NRV is there, but only one breather is there? 95% rule (close enough is good enough!)?
A little while back G posted a French bike shop that had various parts. The Web site was http://italbikeshop.fr/
If it comes good, I will have one in Anthracite please....
Hope it helps.
Cheers.
Nick.
Hope it helps.
Cheers.
Nick.
There is a variation in 907 tanks. I have seen one with a single breather while most have 2.
- Derek
- year: 1994
Since the tank on my 907 is currently unbolted with the hoses disconnected I had a look at the underside. Unlike the one in on eBay it has 4 hose fittings. From the front they are fuel delivery, fuel return, drain, vent. The one on eBay appears to be missing the drain pipe.
This a picture of the underside of my tank.
I have one on stock.
Please send e-mail to info@duc-only.nl
Thanks. That is the same as my current tank. Although neither the bleed or drain pipes were connected when I got the bike... Luckily I didn't ride it....Derek wrote:Since the tank on my 907 is currently unbolted with the hoses disconnected I had a look at the underside. Unlike the one in on eBay it has 4 hose fittings. From the front they are fuel delivery, fuel return, drain, vent. The one on eBay appears to be missing the drain pipe.
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
1980 LAVERDA JOTA
1982 HESKETH V1000
I also have a brand new red 907 tank if you need one. Bought it new from Bologna years ago. Unfortunately there is a small dent at one of the front corners due to transportation damage.
Cheers, Mark
Cheers, Mark
