New Aftermarket Shock for 907?
sungamma
Post by sungamma »
Howdy. Was wondering about recommendations for new aftermarket shock for our beloved 907. Recommendations? Is the stock one rebuildable and is it even worth it? Please respond via email instead of PM if possible because I cannot check this site too frequently. (sungamma@aol.com)
Thanks!
Gary
DesmoDog
Post by DesmoDog »
I can't help with a shock recomendation, but if any one can I hope they answer on the forum since I'd be interested in finding out too.
-Craig
jcslocum
Post by jcslocum »
Dug out the info on my Paso750 Rear SHock:
Fox Racing Shock
399-16-000-1
997-15-005A (Ducati Paso 750)
039-08-059-A Spring: [7.000 TLG x 2.250 ID x 350 lbs/in
This is from the invoice direct from Fox, 408.269.9201.
Total cost back in July of 2000 was $609.00
sungamma
907 shock
Post by sungamma »
Thanks for the data. Is this the same for the 907ie as for your 750 Paso? BTW, the Fox has got to be way cheaper than an Ohlins....
persempre907
Post by persempre907 »
now on eBay you can see an overhaul kit for the 906/907 shock.
If you're interested...
http://cgi.ebay.com/Ducati-PASO-906-Mar ... dZViewItem
sungamma
paso shock rebuild?
Post by sungamma »
Wow, thanks for the link. Can you provide a translation so I know exactly what I'm getting? Also, it say's it's for the 906. Is the 907 shock identical?
Thanks,
Gary
sungamma
aftermarket shock
Post by sungamma »
FYI, just talked to Fox and they no longer make shocks for ANY streetbikes. Also looked at Ohlins website and they do not have a shock listed for the 907 (bummer).
qldman36
year: 0
Post by qldman36 »
Spend a little time in the archives and you will see i spent about year and a half trying to find Ohlins for my 907. Ohlins built shocks for the 750 to Ducati specs. These were only available thru Ducati network. They never built and will not custom build for 907. I know, i tried.
Best option in my opinion is Penske 8981 series which they will valve and spring to your weight and riding style.
If you are interested in a good stock shock, i sold my 907 a few weeks ago and gave new owner the shock which has 6000 miles total on it and needs only nitrogen recharge[any decent dirt bike shop]. Cliff says will put on Ebay eventually.
keepsdad
Post by keepsdad »
haven given this much thought really, but yes i do have the original 907ie shock that carl gave me when i bought his 907 with the penske shock.
as carl said it is in superb shape ( i.e. 6000 miles of usage ) and only needs to be nitrogen recharged.
anyone interested in purchasing please contact me via pm and we can discuss.
thanks.
wilbur
Fox Shocks
Post by wilbur »
I was told by my local bike shop that RaceTech took over/bought out Fox's streetbike shock line. I don't know if this is true but it never hurts to make a call. http://www.race-tech.com
persempre907
Re: paso shock rebuild?
sungamma wrote:Wow, thanks for the link. Can you provide a translation so I know exactly what I'm getting? Also, it say's it's for the 906. Is the 907 shock identical?
Thanks,
Gary
I don't know the German language, but I can translate the text with Altavista :D :D :D :D
So, this is its translation "Ducati PASO 906/907 original shock absorber repair kit again!!! This set is new and was never installed. With this kit the complete shock absorber can be overhauled. All necessary parts are contained".
Perhaps, this could be not a perfect British English, but I'm quite satisfied.
ducwad
Post by ducwad »
I purchased a couple of these kits from this vendor earlier this year. If there are any questions about the individual pieces I can break one out and look at it for you.
The transaction was flawless. I would buy from them again.
- mark
don_zielke
Post by don_zielke »
Works Performance shows shocks for all the Paso models:
Street Bike Application Guide
I had them build a custom shock for my VFR years ago and they were great to work with.
Rasser
year: 0
Post by Rasser »
Hi all,
Some 5 yrs back I made a deal with the importer of Ohlins (and Ducati) in Denmark to make me a shock. So I have a fully adjustable Ohlins rear shock. It was aparantly made from some old drawings that he had lying about and it first cam with a grade 5 spring. Much too soft and was changed to a "7" and later to a "9" which does work fine with the bike.
If the information of this rebuild is still available and if your local Ohlins person will touch such rebuilds is the question.
Anyway it can be done. Race Tech, Penske and maybe others are surely capable, but if they are willing to do this for our historic bikes are another thing.
Good luck.
Per
907IE -92
Black
persempre907
ducwad wrote:I purchased a couple of these kits from this vendor earlier this year. If there are any questions about the individual pieces I can break one out and look at it for you.
- mark
Obviously, I also bought a kit.
There are the gaskets and the bearing.
I confirm the transaction was flawless, even if I guess the seller don't know very well what's selling.
Ciao.
