Many apologies for not keeping you updated with ongoing saga (posted 24/09/06)
I managed to remove valve head from horizontal cylinder and found piston fine but problem being exhaust valve not seating properly and burnt hence low pressure.This both valves were reground and new shims fitted when replaced still not running right.
Problems starting which in turn is flattening battery.
Will start after time on fully charged battery( new and correct size fitted )
Runs perfect when starts,but when turn off and try to restart wont and seems to be kick back at sprag bearing.
As of Saturday Ive give up in my efforts to find problem,now in hands of Very good resonably priced Ducati mechanic.
My friends tell me I should let her go but...............
Ill let you know
Cheers Timbo
Timbo
