Hi team!
I have a split in the pressed steel brace across the frame to which the gas tank bolts at the aft. I am going to have it welded tomorrow. Directly under the brace there is a black plastic box which I cannot identify. My Italian translated service manual refers to it as a balancing tank. There is a line- probably oil- which leads from the black box to the crankcase, I believe.
I have to remove this "tank" to do the welding. Any idea what it is? Is there any magic to removal or cautions I must exercise?
Thanks in advance for your knowledge and help.
Please direct a reply to my email as well as here if you don't mind. smseigel@shaw.ca.
Thanks again,
Pasophist
MYSTERY BOX???
- streetsurfer
- wilbur
Everyone removes this box when they convert to individual carbs like Mikunis or Dellortos. Because there is no longer a way to pipe it into the stock airbox which is no longer used. You can install the little black box back if you wish or you can install a crankcase breather filter directly on the hose from the engine.
check out this thread http://ducatipaso.org/modules.php?name= ... pic&t=1513
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
Tim
Port Murray, NJ
1999 Ducati 996
1998 ST2
2000 Honda RC51
pasophist
- year: 1993
Thank you!
Thanks everyone.
I learned from your replies and my investigation that it is an accumulation tank for oil which splashes or is atomized in the crankcase. The oil travels through a PCV valve to the tank, then the tank has the long breather hose which exits (in my case) along the port side of the bike- to the rear. I have no original airbox and two Dellortos with K&Ns. Its a lot of plumbing for not much utility. I also found the "captured" bolt receiver in the box to be corroded to the nut and had to force it out of the tank. I was concerned about the large size PCV valve being replaced, so I decided not to substitute this system with the crankcase filter as one of you suggested. I guess I could have put it in after the valve. I replaced the tank and hosing after my welding (epoxied the tank top closed and switched the bolt for a stainless self tapping screw). The tank had almost nothing in it- about 20cc of oily liquid- probably from condensation.
As for the weld, the pressed steel "bridge" to which the fuel tank bolts at the rear was split and I had it arc welded up. As I could squeeze the bridge together somewhat I believe the part contributes some minor degree of rigidity to the frame, so I am looking forward to a test ride when it stops raining to beat the band!
Thanks again. Next operation- locate replacement fasteners for the fairing. Any ideas?
Pasophist.
Pasophist.
- wilbur
Look here for some info on body panel fasteners.
http://ducatipaso.org/modules.php?name= ... pic&t=1468
Tim
Port Murray, NJ
1999 Ducati 996
1998 ST2
2000 Honda RC51
Tim
Port Murray, NJ
1999 Ducati 996
1998 ST2
2000 Honda RC51
