750 Paso Technical FAQ Digest
jcslocum
VIN # Explained
Post by jcslocum »
VIN # Decoded or How to Understand YOUR VIN#
VIN Number Info
Ducati US Vehicle Identification Number (VIN)
Characters 1-3: World Manufacturer Identifier
Z = Italy
D = Ducati
M = Motorcycle ( i.e. ZDM = Ducati)
Vehicle Descriptor Section. The 4th through 8th positions in the VIN are the Vehicle Descriptor Section or VDS. This is used, according to local regulations, to identify the vehicle type and may include information on the platform used, the model, and the body style. Each manufacturer has a unique system for using this field.
Character 4: Motorcycle Type
1 = street version
2 = dual purpose version
3 = off-highway racing version
Character 5: Motorcycle Model
D = (example: 1987 Paso 748)
G = (example: 1987 750 F1 Laguna Seca)
H = homologation model
K = (example: 1990 750 Sport)
L = supersport
M = (example: 1992 Paso 907ie)
N = (example: 1993 750SS)
P = (example: 1995 E900 Elefant)
S = hypersport/superbike
R = monster,
T = sport touring
U = 9X9 series
V = Multistrada
Character 6: Engine Type
A = air-cooled twin
B = liquid-cooled twin
C = air/oil-cooled twin
7 = race model variations
9 = race model variation
Character 7: Engine Displacement
1 = (examples: none)
2 = 600cc (examples: 620SS)
3 = 750cc (examples: Paso 748, 750 Sport, 750SS, 748/R, Monster 750, 749)
3 = Australian 1996 900SS
4 = 900cc (examples: 900SS, M900e Mike Hailwood)
5 = (examples: 996, 998, 999, ST4S)
6 = (examples: 851)
7 = (examples: 888 SPO)
8 = (examples: 916, Monster S4, Monster 1000)
9 = (examples: 996R)
0 = (examples: Mike Hailwood Mille 1000)
Character 8: Net Brake Horsepower
The following examples are for US models except where noted.
H = (examples: 1990 750 Sport)
K = (examples: 1999 750SS, 2003 620SS)
L = (examples: 1995 E900 Elefant, 1998 Monster 750)
M = (examples: 1993 750SS, 1987 750 F1 Laguna Seca)
N = (examples: 1987 Paso 748, 1992 Paso 907ie, 1992 900SS, 1994 Monster 900, 1999 900SS, 2002 MH900e Mike Hailwood)
P = (examples: 1998 ST2, 2003 Monster 1000, 2004 Multistrada)
R = (examples: Mille 1000 Mike Hailwood, 1990 851, 1993 888SPO, 1998 748/S)
S = (examples: 1995 916, 2002 Monster S4, 2000 748R, 2003 749)
T = (examples: 1988 851 Tri-Color Racer, 2000 996/S, 2002 ST4S, 2003 999)
V = (examples: 1998 916SPS, 2000 996SPS, 1999 998/998S, 2003 999S)
Character 9: Check Digit
A calculated number that is used to verify the validity of the VIN.
A single number or the letter X only.
Character 10: Model Year Code
9 = 1979
A = 1980
B = 1981
C = 1982
D = 1983
E = 1984
F = 1985
G = 1986
H = 1987
J = 1988
K = 1989
L = 1990
M = 1991
N = 1992
P = 1993
R = 1994
S = 1995
T = 1996
V = 1997
W = 1998
X = 1999
Y = 2000
1 = 2001
2 = 2002
3 = 2003
4 = 2004
5 = 2005
etc.
Character 11: Manufacturing Plant Code
B = Bologna Italy
V = Varese Italy (the old MV factory)
Characters 12-17: Production Number (six-digit sequential)
Frame numbers of bikes wich don`t have the US VIN would begin with:
750 Paso - ZDM750P…
906 Paso - ZDM906PC…
907ie - ZDM906PI2…
900 SS - ZDM906SC2...
Engine numbers
examples:
ZDM 916W4 000xxx
ZDM = Ducati
916 = 916cc capacity
W = water-cooled
4 = 4 Valves
ZDM 904A2C XXXXXX
ZDM = Ducati
904 = 904cc capacity
A = air-cooled
2 = 2 valve
C = carburated
streetsurfer
Post by streetsurfer »
Testing the Voltage Regulator
Image provided by paso750/Gerhard.
stator & regulator rectifier fault finding chart (from ELECTREX)
http://www.box.net/shared/u6ny9gj6s0
http://www.box.net/shared/sflb8n5fzx6r93diav8t
jcslocum
Post by jcslocum »
Front Fork Springs
Looking for new fork springs?
http://forums.ducatipaso.org/viewtopic.php?f=1&t=1557
Stanchion tube length / fork length
Paso 750
left: 580 or 590mm
right: 560mm
Paso 906
left: 630mm
right: 600mm
907IE
left: 640mm
right: 610mm
jcslocum
Post by jcslocum »
Wire Size Conversion US AWG to METRIC
http://www.rbeelectronics.com/wtable.htm
Alternative ignition coils
for Ducatis with Kokusan ignition
NOLOGY: ProFire PFC-30S (152 051 300)
Andrews: CW140403
Dynatek: DC3-1 (the green ones) or DC10-1 (the black ones)
Dynatek miniature: DC3-3 (DC3-2 = set of two coils)
VOLT-Tech (VTwin Manufacturing) (VT No: 32-0484, orange)
Daytona Twin Tec Mini Single Fire Coils (p/n 2006)
Andover Voodoo Single Fire Coils (voo-021 = 3 ohms, voo-023 = 5 ohms)
original coils of carbed (not fuel injected!) Monster/SS (primary 3.8-5.2 ohms, secondary 10.8K - 16.2K ohms, plug cap 5K ohms)
Silent Hektik: MotoCoil (recommended only for use with Silent Hektik ignition module as coil resistance is 2.7 ohms)
The P750 (California model) with Marelli Digiplex ignition uses Marelli BAE 209BK 7J coils. These have about 0,35-0,4 ohms resistance. Same as the ones of the 906.
note: listed NOLOGY, ANDREWS, DYNATEK, VOLT-TECH & Twin Tec are coils with 3 ohms primary resistance (the Dyna DC10-1 are 5 ohms). Using coils with lower resistance than 3 ohms can lead to ignition module damage.
(The 907i.e. being fuel injected and with a different CDI unit uses lower resistance coils. See 907ie FAQs)
jcslocum
Paso Magazine Articles
Post by jcslocum »
Paso write ups
jcslocum
Post by jcslocum »
jcslocum
Ebay searches
Post by jcslocum »
Quick links for searching Ebay
See this thread: http://forums.ducatipaso.org/viewtopic.php?f=4&t=2172
jcslocum
Re: 750 Paso Technical FAQ Digest
Post by jcslocum »
907 Swing Arm On 750
907 swingarm fit info?
http://forums.ducatipaso.org/viewtopic.php?f=1&t=2188
Details on the clock
in case it`s not working and you try to fix it
http://forums.ducatipaso.org/viewtopic.php?f=2&t=2136
Steering, wheel and suspension bearings (P750 & 906)
Steering head bearing (2x)
id* 25mm od* 47mm width 15mm
SKF 32005-X/Q or
TIMKEN 32005X-90KA1 (inner bearing: XAA32005X, outer ring: YAA32005X) or
SNR 32005.V.C12
...with seal (2x)
id 45mm od 52mm width 4mm
i.e. SKF # 17692
Front and rear wheel bearing (2x per wheel)
id 20mm od 42mm width 16mm
SKF 63004-2RS1 / C3 or
FAG 63004-2RS or
RIV 30 L 20
Bearing in the sprocket carrier (2x)
id 25mm od 47mm width 12mm
SKF 6005-2RS1 / C3
(in 750Sport: id 20mm od 47mm width 14mm, SKF 6204-2RS1 / C3 or FAG 6204.2RSR)
Swingarm (same on the 907ie)
Bearing in the right side of the swingarm (2x)
id 20mm od 42mm with 16mm (same as wheel bearings)
SKF 63004-2RS1/C3 or
FAG 63004-2RS or
RIV 30 L 20
Needle bearing in the left side of the swingarm (2x)
id 25mm od 32mm width 20mm
SKF, FAG or INA HK 2520 or
IKO TLA 2520 Z or
SKF (Old No.) RHNA 253220
...with seal (2x)
id 25mm od 32mm width 4mm
i.e. INA 62 G 25-32-4 or Cortego A13 CFW B1OF* 25-32-4 (*B1 = metal ring, OF = ring w/o spring)
Bearing in center linkage mount of the swingarm (2x)
id 20 od 26mm width 20mm
SKF, FAG or INA HK 2020 or
IKO TLA 2020 Z or
SKF (Old No.) RHNA 202620
...with seal (2x) (Ducati part# 075549265, Anello Tenuta ST4-900M-SS/03)
Cortego BAOF* 20-26-4 C18 or Cortego A3 CFW B1OF* 20-26-4 (*BA = rubber shrouded, B1 = metal ring, OF = without spring)
Bearing in center linkage arm (where it mounts to the frame)
id 20mm od 26mm width 30mm
SKF, FAG or INA HK 2030 or
IKO TLA 2030 Z or
SKF (Old No.) RHNA 202630
Bearing in center linkage arm (where the 2 connecting rods are connected) (2x)
IKO TLA 2020 Z or
*id = inner diameter, od* = outer diameter
jcslocum
Post by jcslocum »
Starter Brush Replacements / starter rebuild
In case the starter motor is starting to act up never hit it with a hammer ! On the inner side of the starter housing there are magnet plates which can break. Also if the brushes are worn they could fall out of their guide ruining the rotor.
The brushes are 6x9x12,5mm.
Also used on:
Kawasaki ZX750 (1996-2003) & ZX900 (1994-1997); part numbers: 14079-2055 & 21169-1058
Honda; part numbers: 31201-HA0-004 & 31231-ZA1-003
http://forums.ducatipaso.org/viewtopic.php?f=1&t=2573
http://forums.ducatipaso.org/viewtopic.php?f=2&t=4449
http://forums.ducatipaso.org/viewtopic.php?f=1&t=4870
http://www.electrexworld.co.uk/smbk175- ... 221-0.html
The bearing on the power take-off side is a 6002 (verify with your original if it is a RS, 2ZR or other).
On the rear there`s a low maintainance slide bearing with the measurements 10mm x 14mm x 10mm (Id x Od x height).
The oil seal is a BASL 15-24-6 (or 5, manufacturer Simrit).
In case the starter motor turns but you hear strange noises from the engine and the bike won`t start after replacing the brushes it could be the starter was not assembled correctly making it spin in the wrong direction. The noise comes from the starter sprag clutch which is then also running reverse (which can damage it). Looking at the left side of the engine (alternator cover removed) the starter pinion has to turn counterclockwise. This is the same rotating direction the starter sprag clutch will lock.
There are marks on the front and end cap of the starter motor as well as on its center body which must align. While there are line marks on the end caps and the front (drive shaft side) of the starter body its rear mark is a square and on the opposite side. The marks of the rear cap have to align with this square.
In case you replaced the starter sprag clutch, too you should verify if it`s an incorrectly assembled starter motor or a reversed mounted starter sprag clutch.
aftermarket exhaust systems that existed for the Paso series
http://forums.ducatipaso.org/viewtopic.php?f=9&t=2879
Desmo_Demon
Instrument Cluster Vibration Damper Alternatives - Cheap
Post by Desmo_Demon »
From May of 2007....
http://forums.ducatipaso.org/viewtopic. ... 992#p12992
Public Service Announcement - For future reference, the vibration dampening mounts for the instrument cluster have an M4x.70 thread with each thread section being 3/8" (9.5 mm) long and the rubber section 3/8" (9.5 mm) in diameter and 3/8" (9.5mm) in length. I surfed through McMaster-Carr's catalog and the M4x0.7 with the same sized rubber or neoprene section but 1/2" (12.7 mm) threaded sections are Part #9376K111 and $1.50 each. This means that you can buy this part MUCH cheaper than the OEM, but you will have to cut 1/8" (3.2 mm) off of the threaded section that will go into the instrument cluster so you don't break the housing (it is a blind hole). I hope this helps save someone a few bucks in the future.
Edit - Price on June 18, 2021 is $1.77 each for part #9376K201 listed as the one with the metric thread....
http://www.mcmaster.com/ctlg/DisplCtlgP ... 4977851946
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
jcslocum
Post by jcslocum »
