Help get an ole' bike going again
Tori
Post by Tori »
Hello group........ Looking for some tips on getting this 906 conversion bike going. I have a classified ad http://ducatipaso.org/modules.php?name= ... pic&t=1707 posted for the bike, and am trying to get it running and road worthy before getting serious about selling.
At anyrate, here are a couple issues :
I have checked for spark, and only get a random spark every once in awhile from the rear cylinder. Have not checked from cylinder yet, but a quick shot of starting fluid directly into that carb and it didnt even fire once, so i dont think im getting spark there either.
The bike is missing its side stand, and i see that the warning light on the cluster is lit when key on, Pushing in the plunger on the sidestand switch makes the light go off, but has no effect on spark.
The bike is a conversion 750/906 and there are about 8 wires or so not connected. I have no idea if they are just unused from the conversion, or if they are part of the problem.
Are there any other fail safes that might be keeping me from getting spark ? Or can you point me where to start checking next.
Thanks, TORI
Desmo_Demon
Re: Help get an ole' bike going again
Post by Desmo_Demon »
Tori wrote:The bike is a conversion 750/906 and there are about 8 wires or so not connected. I have no idea if they are just unused from the conversion, or if they are part of the problem.
The intermittent spark would tell me there may be a short, loose connection, or bad ground on the bike. The first thing I'd do is clean all the grounds and check all the connections. After this, I'd get a 750 wiring schematic and a 906 wiring schematic and figure out which system you have. If it is a combination of the two, it will probably make troubleshooting more difficult. I would almost rule out a bad pickup or coil, as typically those are either good or bad.
Here's a schematic of the 750 in color...
http://members.aol.com/TBoling125/facto ... iagram.jpg
Here's a schematic of the digitex system (California model)...
http://tinyurl.com/2vguxt
Here's a 906 schematic...
http://forums.ducatipaso.org/viewtopic. ... tit&lid=37
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
persempre907
Post by persempre907 »
Tori wrote:The bike is missing its side stand, and i see that the warning light on the cluster is lit when key on, Pushing in the plunger on the sidestand switch makes the light go off, but has no effect on spark.
Hi Tori,
Do you mean that when the side stand is open the engine would turn off?
The engine doesn't turn off when the side stand is open, only the red lamp on the dashboard turns on.
PascoPaso
Post by PascoPaso »
So the sidestand circuit is a good place to test for sure. My guess is that only the frame is a 750, the rest is 906, including the ignition and wiring. At the ignition module on my digiplex there is a two wire plug that can help you troubleshoot the voltage to the module. One is charged, one is ground.
Tori
Post by Tori »
Thanks guys for the help. I think it is a bad connection. Tonite i was talking to the owner showing him how it didnt have spark..... crank.......crank........crank...... spark. crank....... crank,......crank..no spark. :thumbdown: Then i let off,.....and hit it again... and bam..... SPARK like its supposed to. :thumbup:
Now that i had spark i continued with getting it started. Found the fuel pump disconnected, fixed that, heard the float bowls filling up, hit the starter and after a few pops, she ran. :thumbup:
Actually ran pretty well. Takes throttle, no valve train noise, and rev's quickly.
Now i just need to figure out the no charge condition. It has a brand new regulator/rectifier.
But now that it runs, $1500 shouldn't be as hard a sale. Any takers ?
