38mm mikunis
38mm mikunis
I found a set of 38mm mikunis for sale. I was going to play with the weber but then I saw these for sale. They are off a 95 900ss. Are they OK for the 750 or should you stick with the 36mm? The price is right. Of course the I have to find manifolds and all the rest to convert over not sure how much that would add up to.
- persempre907
The 38 mm. Mikunis will go well.
Here you can have some good advice.
http://forums.ducatipaso.org/viewtopic. ... cle&sid=29
- persempre907
