different sprockets?
sprintex
year: 0
Post by sprintex »
Ok my other problem now is the rear sprocket. Then one I got from Bevel Haven is bigger in outside diameter and the inside diameter then the one that is on the bike. Totally different. A friend of mine gave me a pair of sprockets from his Paso that he used to own and they match up to the new one I got but not to the one on the bike. As far as I can tell it is the stock wheel.
So are there two different type of sprockets for the Paso? The hub would have to be different I would think since the bolt pattern is different.
I'm really perplexed here. Though the sprocket that came on the bike is from Sprocket Specialists and so is the replacement.
streetsurfer
Post by streetsurfer »
A sprocket specialists replacement that I have is numbered 187Z. I looked on their site and it says Z sprockets are not all listed, requiring a phone call to order. I am not sure if that is their designation for the alloy titan tough ones or what. If you can get them to swap you a corresponding match to that number it should fit.
sprintex
year: 0
Post by sprintex »
OK, thats the number on the one that came on the bike.
