NOW my question is i buy a cheap oil (like car 20 w 50) to wash the engine inside and pt in new good oil or buy new good oil directly??
Many Thanks
Piero
+1......My Harley has lots of blow-by (has 92k miles on it), and the oil is always dirty. One of the reasons that I change it every 2000 miles is because of how dirty the oil gets......also remember that you never totally remove all the oil when you do an oil change, so you are mixing some of the old, dirty oil with the new stuff.jcslocum wrote:The dirt may not be in the engine. It may come from running the engine in the form of blowby or other combustion junk getting into the oil. Heat is also a real oil killer.
You have small amounts that are puddled in various parts of the engine (heads, oil sump/crankcases), and you also have oil in your oil lines and the oil coolers that is not drained when you replace your oil. This old oil, especially if fairly dark and full of contaminates, will change the color of the new oil in a few seconds of the engine running.persempre907 wrote:WhyDesmo_Demon wrote:...also remember that you never totally remove all the oil when you do an oil change, so you are mixing some of the old, dirty oil with the new stuff.???
