HELP need all three thermosensors
slopaso
Post by slopaso »
HELP i recently bought a (supposedly) fully restored 907. i even spoke to the mechanic who worked on it. shipped it home and it looked great but turns out the geniouses before me forgot to put in coolant and now i need all three sensors in the coolant system: the 'thermostor' (part 0370931807), the 'water temp sensor'
(part 700010001), and the ' temp switch' (part 55240013A ). is there anyone parting out a 907 or knows where i can get these parts?
Shelboss
Temp sensors
Post by Shelboss »
See my request for info on the air temp sensor, there are some useful links to specs and cross-references there. Turns out my sensors were fine and I had a shorted wire, so test them first. They start off at about 3k ohms at ambient temp and resistance goes down as you heat them. Even if you cooked the water temp, why would the air temp and air pressure sensors be affected?
