907 sprocket ??
- Cybermunster
907 sprocket ??
anyone know offhand how many teeth on the OEM rear sprocket for the 1991 907s?
thanks
thanks
- Cybermunster
- Finnpaso
- year: 0
I use 15 / 46(!!!) gearing and never go back to normal anymore. Fits much more better to my driving style...
Btw, near all modern Ducatis are geared from factory too low, to meet allkind of noise and emission, etc standarts... Same with original exhaust systems. Its quite rare to see, that someone drive his/her Ducati with normal gearing or with normal exhaust pipes...
:laugh: :laugh: :laugh:
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- Finnpaso
- year: 0
Many times...(but too expensive to me, cause after 3 hour driving good tires are ready to change
) and i like drive fastly in twisty roads. I like to use just ALL gears in twisties, where speed is not "so high", like in motorways, which are very boring to Ducaties.... Surely driving style is very important, if thinking gearing. If need to drive fastly in German motorways, then need surely lower gearing. I hate such roads, so thats why i use big rear sprocket.... Btw, 750 Paso gearing dont need so much changes, but 907 and ST4S needs totally different, than OEM sprockets. Sorry, i wanted to say, that ALL ST modells need!!!
Btw, that gearing depends very much about race track. If shorter track, then higher gearing and via versa...
907IE -91 red
907IE -91 red
- Cybermunster
- Cybermunster
stock/modified gear ratios
Stock gearing for 907ie chain wheels is: 15/40
I'm running 14/42 on all my 907ies and prefer it. I went down one tooth in the front and up two in the back.
Since the front chain wheel is smaller, going down one tooth in the front has more impact on power delivery than going up one tooth in the rear. Going from 15 to 14 teeth reduces the circumference of the front chain wheel by almost 7%; increasing the rear chain wheel to 41 teeth only increases rear chain wheel circumference by 2.5%)
'91 907ie (Red)
'93 907ie (Red)
'93 907ie, w/ worked engine (Red)
'07 1098S (Red)
'07 MV Agusta F41000R
'82 Kawasaki KZ1100 Spectre (Wine/Black)
'93 907ie (Red)
'07 1098S (Red)
- Cybermunster
blakduc1
My 1992 907ie came with a 40 tooth rear and 15 tooth front, I believe. The 40 is nice easing along for long jaunts at 70 or 80, like intersate highways. But--- it will likely not pull top end speed with the 40 tooth rear. Theoretically gives you more top end speed with the 40, but if it can't attain it, what good is that? I use 42 tooth on both my 907s and it gives better power, easier clutch actuation at take-off, and will pull top end easier. I have used 41 tooth also, but not a lot better than 40.
I say use 42, even though rpm will be a little higher at a given speed. Better for mountain road running....
dp
dp
