Fan does not stop
hardo
year: 0
Fan does not stop
Post by hardo »
Hi everyone, the electric fan in my Paso 906 (1990) starts running too early (at approx. 75 instead of 92 Celsius) and does not stop anymore (it runs as long as the battery has power). Hence to avoid the battery running out, I have to remove the fuse and wait till the engine is cold (if not, the fan starts running again). Any idea what I should do? Thanks a lot for your help and keep on riding, hardo :thumbup:
ducapaso
Post by ducapaso »
temp switch broken.
JWilliam
Fan does not stop
Post by JWilliam »
I have a fully electronic controller for my fan because I run my Paso with two radiators so have had to ditch the standard bi-metallic switch. The circuit is a modified Velleman thermostat and I can vary the switch on temperature along with the switch on at - switch off at - setting (hysteresis).... But it took a bit of doing.
Finnpaso
year: 0
Post by Finnpaso »
"JWilliam": I am very courious, HOW You did it, so can U explane more? :confused: I added to my 907IE 2 extra small fans with normal switch in right handlebar to put more fans on, if driving in hot conditions in cities with low speed. When speed is higher, then it automatically cools engine more, so then i switch off those "extra fans"... :evil: Btw, do You have 906, or 750 Paso?
907IE -91 red/metal grey
907IE -91 red
JWilliam
Fan does not stop
Post by JWilliam »
Well I wouldn't be running a water cooled 750!, its a 906. When you say you are curious, do you mean the second radiator or just the electronic fan control?
Finnpaso
year: 0
Post by Finnpaso »
both, 2. radiator AND electronic system of Your fan. Sorry, i didnt know, that You had 906. :thumbup:
907IE -91 red
JWilliam
Fan does not stop
Post by JWilliam »
I will send you a private message.
Finnpaso
year: 0
Post by Finnpaso »
Thanks already for You. :thumbup: :thumbup: :thumbup:
907IE -91 red
ducatipete
Post by ducatipete »
Buy a replacement switch from a car parts supplier, as switch is
same as fitted to many Fiat cars and will be cheaper ...m20 thread :lick:
hardo
year: 0
Post by hardo »
Thanks for your help, Hardo
ducatipete
Try (Fiat) intermotor part no 50200, 92/87 degrees as std ducati one with same spade connectors and paid $20 :lick:
Finnpaso
year: 0
Post by Finnpaso »
Very good, but TO WHAT FIAT modell is it ??? Punto, Bravo, etc.... I know, that they ask it, when going to Fiat shop... :ugh:
907IE -91 red
ducapaso
Post by ducapaso »
Maybe older models, since uno, ritmo and later.
They use to put a short cable out of the switch in earlier models
hardo
year: 0
Post by hardo »
Thanks a lot...does anybody know if the temp switch has two electric connections or just one? all the best and keep on riding, hardo
ducapaso
Post by ducapaso »
Usually temp switches have 2 pins, as they aren't connected to the ground.
Otherwise, switches for temp indicator/red light can have just one pin
