Clutch kit
eliatt
Clutch kit
Post by eliatt »
I`m having difficulties finding a clutch kit for Ducati 750 / 906 Paso - they become scarce around these parts...
Questions are:
will the 907 kit fit?
Can Anyone recommend on a good web shop that carry Paso parts?
Thanks,
Eli Attias
Post by Tamburinifan »
Since 906 clutch is dry, doesn`t almost any Duc dry one fit (except some late R ones)?
Think f e all 900 dry clutches from the 90`s are interchangeable.
My 907 is dry.
Not sure what a 750 has.
Finnpaso
year: 0
Post by Finnpaso »
I am quite sure, that 907 kit fits to 906, but have those early 906s(slave sylinder in right, like in 750 Paso) samekind disc kit, as later 906s with slave sylinder in left??? :confused:
907IE -91 red/metal grey
907IE -91 red
f1steveuk
Post by f1steveuk »
EBC in the UK (although they sell worldwide) list kits for the 750, 906 and 907ie, and I am sure there's a full comp kit listed on http://www.demontweeks.co.uk
eliatt
Post by eliatt »
Thanks all,
As I recall, difference between all dry right sided actuator models is only the use of thick one- sided friction plate, close to the "c" clip spring. this set up is used on Paso 750, 1989 Paso 906 , 1988-1990 750 sport, and early model 750 ss. the 907, I dont know about: never imported to Israel...
However, if there is a way to do without that one - sided plate on top, I`ll be more than happy to learn more about it. maybe replace it with a double sided one?
Thanks again!
Eli
