Mono question
ducapiero
year: 1985
Mono question
Post by ducapiero »
Hey guys now i'm in very hardstudying period and i'm searching for bike spare parts(improvement only :cool: :thumbup: :thumbup: )....
i'm buying a rear wheel of 17 and i'm thinking to change the marzocchi mono with something more performant from some other bike.....
I noticed that the lenght of us mono is 35,5 cm from hole to hole,if i take a mono of this lenght from another bike ,this will fit or i could have problems??
all suggestion are welcome :D
lamps
Piero
Desmo_Demon
Re: Mono question
Post by Desmo_Demon »
ducapiero wrote:I noticed that the lenght of us mono is 35,5 cm from hole to hole,if i take a mono of this lenght from another bike ,this will fit or i could have problems??
You may be able to find a shock of the same length that won't have any clearance problems when mounted on the Paso, but if the suspension of the donor bike is significantly different (distances from pivot points and differences in linkage), you'll find that the spring rate, dampening, and compression rates may not be compatible with the Paso's suspension geometry......and has the potential to make the Paso dangerous to ride.
If you find a shock that works, please let us know, as I'm sure a lot of us wouldn't mind having better or newer shocks at an affordable price.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
ducapiero
year: 1985
Post by ducapiero »
I noticed that a gsxr mono has the same paso suspension geometry and most impiortant the same lenght 35-36 cm.
i want to investigate more if i find some news more significant i'll give you notice :thumbup: :thumbup: :thumbup:
lamps
Piero
