Adjustable rear sets
Stefano
- year: 0
Do you know if there is manufacturer of adjustable rear sets for Paso?
Thanks!!!
http://www.geocities.com/750paso/paso/italie.html :screwy:
Thanks!!!
- persempre907
Ciao Stefano,
there are many footpegs which fit on the Paso.
You can see on eBay and you have to search the footpegs which fit on the Paso (obviously), but also on the 90's SS, ST, 851/888.
For example
http://cgi.ebay.it/DUCATI-851-888-900SS ... dZViewItem
For example
- persempre907
Stefano,
I'm not sure you will able to find some adjustable rear set of footpegs.
Perhaps, you'll find (but it will be difficult) some front adjustable footpegs, but the rear ones...
The rear adjustable footpegs would also make raise and lower the mufflers...
No matter, good luck and let us know.
- Desmo_Demon
If I remember correctly from a few months ago, I checked the mount spacings of a rearset from a 748/916/996/998, and the mounting holes looked to be the same spacing. If this is the case, adjustable rearsets from any of those Superbikes would work. I'll try to remember and check the spacings, again, when I get home and post my findings here.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- Desmo_Demon
I remembered correctly. Here I took a spare rearset from a 748/916/996 and mounted it to one of my spare Paso frames. It bolted directly to the frame with no modifications at all, so the 748-998 superbike rearsets will bolt right on to the Paso frame. You may have some issues with the shift lever and rear brake lever linkage and mounts, though....Desmo_Demon wrote:If I remember correctly from a few months ago, I checked the mount spacings of a rearset from a 748/916/996/998, and the mounting holes looked to be the same spacing.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- Desmo_Demon
+1....Good call. I forgot about that possibility!Duc750 wrote:Clearance around the exhaust cans could well be an issue too - good luck
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
