I have overhauled the clutch pump and slave cylinder and bleed the system. All is working fine however I can't remember which way the hose was routed. Does the hose pass in front of or behind the head stem? I currently have it passing forward of the head stem however it appears that at full left lock the hose rubs more than I think it should. I feel that if I were to make it pass behind the head stem, then at full left lock it would have some fairly big bends on it however I could be wrong. I should have checked it out before bleeding or taken more notice prior to disassembly but!!!
Clutch hose routing.
- Desmo_Demon
So.....how is it supposed to be routed? I was going to tell you how mine was routed, but I have no idea if it is correct or not. The previous owner took the bike apart to powdercoat the frame, and, from what I can tell, didn't really know what he was doing when he put it back together. :laugh:kirk332 wrote:Problem sorted. It works out that I did take more notice during disassembly. I found a piece of paper lying around the floor of the garage which had explicit instructions on said hose, and how it was routed. Must have been one of those 3 am jobs!
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Mine was routed pretty much how I had it, that is as discribed above in my initial post. I could take a couple of pics if u need however I am away at work for the next two + weeks and would have to wait till then.So.....how is it supposed to be routed? I was going to tell you how mine was routed, but I have no idea if it is correct or not. The previous owner took the bike apart to powdercoat the frame, and, from what I can tell, didn't really know what he was doing when he put it back together.
Cheers KB
- Desmo_Demon
So you had it routed correctly?kirk332 wrote:Mine was routed pretty much how I had it, that is as discribed above in my initial post. I could take a couple of pics if u need however I am away at work for the next two + weeks and would have to wait till then.
Cheers KB
I'll have to doublecheck mine to see how it is routed. Some of the things on my bike are an absolute guess for me whether it is correct or not.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
