Steering Dampner
- redpaso
- year: 1989
- Location: Land of OZ (traylia that is) Troy Bayliss Country
Steering Dampner
Hey guys & Gals, I am just curious to know whether anyone has fitted a steering Dampner to their trusty Paso? if so how? If not do we feel that they even need one?
Redpaso
gasfireman
- year: 1989
- Finnpaso
- year: 0
If i load my 907 with heavy sidebags and sleeping bag, tent, etc, then i can notice very easily, that its horrible to shake in braking, when coming down from hill to tight curves and then steering damper would help alot.... That "weight point" goes totally wrongly, when hard stuff is loaded and then it start to shake, never, if drive without side bags with heavy stuff...
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- redpaso
- year: 1989
Got to agree gasfire I do not see a need to fit one as my 906 does run straight, I was just curious as to whether anybody had & if so how. I am too old for Bling
Interesting though to hear about adding luggage & weight, that certianly changes the whole dynamics when riding, that is why I like to travel as light as possible, ussually just a tank bag, not that I have the chance to get away for any longer than needs a change of undies & a tooth brush these days.
Redpaso
- Desmo_Demon
I'm sure there is always an added benefit to a damper. We put one on my wife's R1 with the idea that "it is better to have it and not need it than to need it and not have it". An example of this would be this past Sunday.....redpaso wrote:Interesting though to hear about adding luggage & weight, that certianly changes the whole dynamics when riding, that is why I like to travel as light as possible, ussually just a tank bag, not that I have the chance to get away for any longer than needs a change of undies & a tooth brush these days.
I've had my '98 ST2 for over 31k miles without any need for a damper of any type. I'd never run across a situation where I needed one, but......Leaving a motorcycle hang-out before a few of my buddies, they finally caught up with me in a long straight section and passed me. I nailed the throttle to limit the distance they put between me and them (the one was riding a 2007 GSX-1000R and passed me at over 150 mph!). There is a kink in the road and a slight hump, which I promptly hit with the ST2 at 90+ mph and nailed the throttle at the wrong time....I went into a tank slapper, but fortunately for only about 20 meters before it straightened itself out and I recovered.....just before going off the road and right into a utility pole, so....
Whether you have ever run across a situation where you needed a damper or not, you just may wind up in a situation where you could have probably needed one. I'm glad I didn't "need" one, but had I been going faster, or the road had more of a curve to it, I just may have needed one.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- redpaso
- year: 1989
Sounds like you probably needed a new pair of trousers as well. Glad you got out of that one...ummm... ok!Desmo_Demon wrote:....I went into a tank slapper, but fortunately for only about 20 meters before it straightened itself out and I recovered.....just before going off the road and right into a utility pole, so....
That reminded me of a ride I had about a year ago when I hid a bump in the road exiting a bend & it created a tankslapper that dented & chipped paint from the tank on both sided & left me with 2 extremely sore & bruised thumbs, I guess a dampner could have saved my thumbs
very good point though, better to have something & not use it than need it & not have it
Redpaso
- Desmo_Demon
In the case of my wife's R1, we'd read that the damper was one of the most popular modifications to the bike (the new bikes have them from the factory). A buddy of mine that raced an '03 and '05 R1 said that there had been some really nasty tankslappers on the track due to not having a damper, so........with my wife already being handicapped from a motorcycle accident, we decided to follow the "better safe than sorry" rule-of-thumb. Fortunately, she knows a guy who works at Ohlins, and he gave us a great deal on a damper for the bike....redpaso wrote:very good point though, better to have something & not use it than need it & not have it
If you can fabricate a way to mount it, the dampers from the 748/916/996/998/749/999 bikes tend to go pretty cheaply on eBay...often with the mounting brackets from the bike, also.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
I thought of this myself longer time ago, but didn`t have a chance to realize this. The mounting brackets of other Ducs won`t help as the damper is either mounted infront of the tank or on the side frame rails which normally are round....often with the mounting brackets from the bike, also
Sticking to the idea to mount it on the side I found a matching bracket to be mounted on the fork tube (I think it came from an older Guzzi), but didn`t find any square bracket to mount the damper on the frame yet. Guess this will have to be machined.
- Finnpaso
- year: 0
"sometimes" i drive my ST4S very hardly (it have much better fork and rear damper, than Pasos have) and i feel, especially just, when front of bike try to be very light ( :laugh: :laugh: ), it start to shake (just, when coming back to street surface)... :laugh: I searched some time ago dampers and find some Toby making damper to ST series bikes. :lick: It comes to left side, between frame and left fork. If i have one day money, ill buy such to my ST....
907IE -91 red
907IE -91 red
