1992 907ie body removal
macwig
Post by macwig »
Thought Id take off the body parts to do some oil change,ect and the tail pieces and the headlight fairing piece of cake.Then getting the front turn indicators wire out stoped me for now.Do I have to remove tank to get to where the turn signal wires go in the central harness??I cut two wire ties and still cant follow the wire....Thanks
Finnpaso
year: 0
Re: 1992 907ie body removal
Post by Finnpaso »
At least i have connectors about 15 com from front blinkers, what needs to open, before can take side fairings off... :)
907IE -91 red/metal grey
907IE -91 red
persempre907
Post by persempre907 »
macwig wrote:Thought Id take off the body parts to do some oil change,ect and the tail pieces and the headlight fairing piece of cake.Then getting the front turn indicators wire out stoped me for now.Do I have to remove tank to get to where the turn signal wires go in the central harness??I cut two wire ties and still cant follow the wire....Thanks
In my bike, the connections are outside the blinkers. So, when I need to service the bike, I keep out the side fairings without removing the blinkers, so only I disconnect the blinkers' wires.
I guess your connections still are inside the blinkers (there is a round rubber which prevents the connection goes out), so you have to remove the blinkers first, disconnect the wires and voilà...
Later, if you'd like, you can also keep the connections out the blinkers, so you don't have to remove them when you service the bike.
Finnpaso
year: 0
Post by Finnpaso »
I only take connectors open and keep mirrors in fairings. First fairings off and then those connectors open with another hand, easy job! :P
907IE -91 red
persempre907
Finnpaso wrote:I only take connectors open and keep mirrors in fairings. First fairings off and then those connectors open with another hand, easy job! :P
I do the same thing...
