Clutch hydraulics
ducatipete
Clutch hydraulics
Post by ducatipete »
Went out today and came back with 2 problems, lost clutch fluid and battery not charging!!!! will search for regulator replacement info on forum, but what about replacement seals for the master cylinder and clutch slave cylinder are they both one unit on the clutch lever or 2 units ie lever and slave (the part with the bleed nipple) on lefthand engine cover? :cry: :cry:
Re: Clutch hydraulics
Post by Tamburinifan »
Master & slave are different units sparepartwise.
You can order seals separately.
Slave seals are most likely to fail first.
ducatipete
Thanks for info, are seals as for 907, as this is the only model local dealer has listed on spares list
ducapaso
Post by ducapaso »
The 6 speed ducati engines should use all the same slave cilynder
it should be easy to check if slave seal failed. Just remove the clutch cover and see if the inner side is dry or not. If it`s dry, the slave cylinder seal is ok.
ducatipete
Thanks everyone, will check in next couple of days :D
ducatipete
Bought an upgraded slave cylinder seal from ebay UK item number 260187771759, fits a treat
AD reads;
"Ducati Quad Clutch Slave Cylinder
Specificaly Designed Quadrupal sided oil seal
To replace troublesome origional seal and banish those clutch fluid leaks that plague Ducati
please see my website (motographix.co.uk) for fitment guide and more details"
End
For bleeding of hydraulics systems I recommend using a Mity Vac, a US product like a hand held pistol, that draws the fluid thro the bleed screw, using vaccuum pressure, you just need to top up the fliud in the reservoir,,,it uses clear plastic tubes so you can see the air bubbles coming out....very quick and easy,,,,has many uses for bikes and cars,,,,,
ducatipete
Clutch slave cylinder has failed again, this time its leaking from the hose connections, the thread is damaged, is the slave cylinder available from DUCATI?
ps happy new year for 2008 !!!
if the thread is the problem a new piston won`t help.
However if that is the issue you can use a HELICOIL to repair the thread. If you never did that before have your Duc mechanic do that.
As for the secondary piston, it`s not available as a single part for the Paso but only as a set incl. bearing etc and it`s very expensive. (I recall someone mentioning $ 200 or so)
You can take the secondary piston from the 900SS dry clutch or 996 etc. (I`m using that myself) Part No. 19590023B (older numbers were 195.2.002.1B or 195.2.002.3B). This one costs ca. 30-40 USD. (it`s the piston only incl. seal w/o bearing and spring). You can use the old spring and the bearing is a SKF 608-ZZ (same as 608-2Z). (the seal ring in front of the piston needs to be removed to fit the bearing)
