PS: the adapter on the side of the front header tube is not original. That part was welded in so for proper engine/carb adjustment a lambda sond can be used. Further advantage is that with a mobile lambda meter you can also check when riding. The adapter costs like €15-20 or so plus welding. Ducati sells it as a single part.
aftermarket companies like this one sell it for € 7.50 ($11) but w/o the short bolt and copper gasket to close it.
