swingarm width 24cm. Terry what`s the wheel width with the sprocket carrier on ?
I'll have to remember to check tonight.paso750 wrote:Terry what`s the wheel width with the sprocket carrier on ?
Sorry....I got side-tracked after work on Monday and drove for 4 hours to get two sets of tires, then I played "hookie" from work yesterday and went on a 300 mile bike ride in the mountains of northern Georgia. I'll try my best to check the measurement of the rear wheel I have this evening.ducapiero wrote:c'mon guys.....![]()
Just stock up on your beer and wine inventory before I get there.ducapiero wrote:demon you 'll be my guest when you'll come in naples
I believe you are correct that the bracket needs to be flipped over so the caliper is on the top side and that the bracket is closer to the swingarm where the pin is located to hold it in place.Finnpaso wrote:From what modell is that Your rear brake caliper holder, cause seem, that caliper will come UNDERside, not upper, like normally ???
Bearings will survive but more important, the spacer will wear into the swing &In the 1992 907 parts schematic, it is listed as "Distance piece #71310321A". If you mount the spacer in backwards (the largest side next to the sprocket carrier), you will probably destroy the bearings in the sprocket carrier.
