WANTED: tire, chain, brake handle, brake pedal, chain
Ferrolanoman
Post by Ferrolanoman »
I need and want to buy for a 1990 750 Sport:
1) 160x60x16 rear tire, slightly used is ok
2) chain and sprockets
3) front brake handle
4) rear brake pedal
5) exhaust cans, stock or aftermarket, exhaust
6) battery
Let me know what you have and how much you want.
thanks for any and all help.
best email: landeira@colorado.edu
Re: WANTED: tire, chain, brake handle, brake pedal, chain
You`ll find most parts at your Duc dealer, the rest on ebay.
Tires may be more tricky to find, but use the search function of the forum, there`re numerous links posted from different shops in the web.
Battery, chain, sprocket and brake handle are parts you should find easily. The brake handle is standard Brembo used on many other bikes the other parts are wear parts that probably most shops selling bike parts/accessories can order.
The exhaust cans of the 750SS may fit, but that I don`t know for sure. The ones of the Paso definetely don`t.
