Gear whine
pasophist
Gear whine
Post by pasophist »
'88 Paso.
45,000 miles.
In third gear I get a lot of gear whine. I think it is getting worse over time.
What are the options of what it can be?
How serious is it likely to be?
What should I do about it?
SMS
jcslocum
Re: Gear whine
Post by jcslocum »
Is this at all speeds/rpm??
Re: Gear whine
... or under hard acceleration combined with a power loss, then it could be a slipping clutch.
Is it only in 3rd gear ? In the worst case the teeth of your gear are worn and if pieces brake off, this could lead to an engine damage sooner or later.
http://forums.ducatipaso.org/viewtopic.php?f=3&t=2259
pasophist
Re: Gear whine
Post by pasophist »
Not the clutch-
at all speeds.
the whine follows the rpm with pitch increasing with rpm.
