head steering bearing
hi, does anybody know where can find the head steering bearing for 906 ? :thanks
Re: head steering bearing
from your Duc dealer
no, honestly were are you located ?
On the bottom right of the SKF homepage you`ll find a list of distributors selling to end customers:
http://www.skf.com/portal/skf_us/home
If you are in Europe and not knowing if the seller will ship outside Germany, this would be a good deal:
http://cgi.ebay.com/2-x-Kugellager-Kege ... dZViewItem
PS: a few days ago I made a summary of bearings in the P750 FAQ
- JWilliam
- year: 1989
Bearing code
The code for the steering head bearing is 32005X-90KA1. The cones will come out with a pin punch but you will need an angle grinder to cut off the bottom bearing.
32005X-90KA1 is a TIMKEN bearing or use SKF 32005-X/Q (id* 25mm od* 47mm width 15mm)
I never needed one.
?!... but you will need an angle grinder to cut off the bottom bearing.
I never needed one.
- jcslocum
The bottom race can be a PIA. If it's hard to remove then cutting a slot in it will make it slide right off.
