What I mean is that the engine will begin to loaded up with unburnt fuel from the very weak spark due to the low voltage and maybe a poorly adjusted carb. At idle with the voltage dropping the coils will have barely enough juice to cleanly fire the spark pulgs. As it gets more rich in the cylinders it will get harder to fire and so on. So a good solid spark is key to a sweet idling engine.rocket_man wrote:What do you mean by load up?
If you read the wiring upgrade thread you saw that during the key on and prior to hitting the starter my coils were seeing like 9.2 volts. This is fully 25% lower than the battery. This low voltage causes a very weak spark and hard starting.
You could also throw a realy in that will turn the headlights on once the bike has started.
