Removing oil filter nightmare
macwig
Just when I get to what I think is the easy job Im wrong.Trying to take off the over tightened oil filter from the previous owner I have exhausted all options.I tried a strap wrench,wide channel locks,a Ducati oil cap wrench(but by now the grip points are all buggered up)and last I drilled a hole and put a large screwdriver through and tried to crank it off but no good.Anyone got any suggestions??Thanks
- Laddie907
Re: Removing oil filter nightmare
righty tighty, lefty loosey...?
might sound dumb but I've fallen for this with bolts and bits in difficult places...
- Skins
I have a chain wrench (there is a chain instead of a strap as in a strap wrench) that works bloody well. Also, a very large plumber's pipe wrench (I mean a large wrench, not a large plumber) might do the job.
- Desmo_Demon
As a last resort, I've heard of people ripping the exterior case off of the filter and then using a hammer and chisel to knock the base counter-clockwise to get it off..........as a last resort.
I wish you luck with it.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- Finnpaso
- year: 0
Screwdriver through filter from good position and then turn it open...... This have fuction here(last opinion)....
Normally very good filter opening tool can open such filter, what cant turn with hands..... (better opinion)
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- ducbertus
I use a "Facom" tool with a toothed metal band you can strap tight with a large knob.
this "killer"never let me down.
Ducbertus
Ducbertus
You could try a large hose clamp or muffler clamp and hammer on that to loosen.
