I'm almost done getting my 88 limited gone thru. but I'm not sure about the front axle parts. I was missing the front axle washer (right side) I have machined a replacement, but the parts book shows 2 different parts as part of the speedo drive, is the second part another washer??? it looks like it in the parts illustration but doesnt mention it in the maint manual description.
also the maint manual says the torque is 50 ft lbs for the axle(seems like alot), will that crush the speedo drive??? any help would be appreciated. John
?????front wheel and axle parts?????
- Desmo_Demon
Re: ?????front wheel and axle parts?????
I'm not too sure abotu this, as I'm sitting at work and can't picture the parts in my mind.Johnnie wrote:but the parts book shows 2 different parts as part of the speedo drive, is the second part another washer???
No, it should not harm the speedo drive, as the internal steel spacer of the speedo drive unit acts as an inner race to a bearing. It takes all of the force from torquing the axle down. The speedo drive ring fits into a little slot on the front wheel and is free to spin once the axle is torqued within the speedo drive housing. There should not be any binding. You can feel how fluid the assembly moves if you have the front end in the air and spin the wheel once you have the axle torqued. It is actually a good practice to make sure that you didn't forget or add any parts unnecessarily and have binding of the wheel. You can also check for brake drag by doing this.Johnnie wrote:also the maint manual says the torque is 50 ft lbs for the axle(seems like alot), will that crush the speedo drive??? any help would be appreciated.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
I look for this problem too, but the other piece of speedo drive no exist, in fact this part on the table have not a number.
Besides, the space between brake rotor and brake caliper on right/left side is exact without any other spacer.
50 ft/lbs not crush the speedo drive because inside part of it is a distance piece.
Saluti Giancarlo
Saluti Giancarlo
thanks for the info guys, I'll be riding the bike this weekend. Thanks Desmo Demon for all the help , I just fired the bike up monday with the F1 muffs and it sounds and runs great. The fender should be back from pain any day. its so close but the wait will be worth it. John
