conversion kit?? It could be an alternative for those who want twin
headlights. A bi- xenon kit only use 35v each so it might work, or what do
you think????
Bi xenons product a lot >less< heat than standard bulbs, so heat will not be a problem. But if you put one in a crappy headlight reflector you're just going to have a more intense, crappy beam. Is the problem with the Paso headlight that it's not bright, or that it's not focussed?harv wrote: My concern is whether or not the heat produced by the Xenon bulbs could damage the existing lens. Anybody know?
H.
