Here is a website http://64.233.169.104/search?q=cache...lnk&cd=5&gl=us which will offer many parts options, not just fuel pumps. But specifically, the BOSCH pump is the one I found to work most successfully, part number 0 580 463 999. It is smaller in diameter then the OEM Weber so packing material must be used to insulate and fix the pump in the factory rubber and plastic bottom bracket. I used butal rubber packing from a water irrigation compression fitting found at a lawn and garden center. I researched the compound through the manufacturer and learned that this material is highly resiliant to fuels so deterioration will not be a problem. The new Bosch pump, rated at 3 bar (46 psi) is more efficient then the stock Weber. It's smaller, queiter and much less expensive. My USA cost was about $70.00 with a sock or gauze strainer fitting, all purchased separately from Bosch throu a local auto parts store. Hope this helps, Steve"
I pray, that this helps at least some 907 owners, because that original pump is not anymore available....
