parts?
mickster
parts?
Post by mickster »
any help to get parts or technical info for a newbie would be appreciated!
Re: parts?
Post by Tamburinifan »
Re: parts?
where are you located and what do you need ? Let us know :)
mickster
Re: parts?
Post by mickster »
Thanks for replying to my post. I live in Pittsburgh, Pa. I was lucky enough to find a blue 87 750 with low miles (4200). The bike is in great shape as it was stored in a heated garage. The parts I need are the chain buffer on top of the swingarm, the little threaded rubber things that hold the instrument cluster to the fairing bracket and parts to mount the centerstand, which I have. Also, I am not internet savvy, so any help is surely appreciated. Hey but I'm learning! Any parts interchage or tire fitment info also. Thanks!
jcslocum
Re: parts?
Post by jcslocum »
Read thru the FAQ at the top of the forum. This is our "encylopedia" of Paso issues.
Desmo_Demon
Re: parts?
Post by Desmo_Demon »
mickster wrote:The parts I need are the chain buffer on top of the swingarm, the little threaded rubber things that hold the instrument cluster to the fairing bracket and parts to mount the centerstand, which I have.
All those parts should still be available through Ducati. If not, ProItalia in California often has obsolete parts on their shelves. I do know that the vibration dampers for the instrument cluster are something like $16 each, but you can get cheaper ones from McMaster-Carr and trim one side down to make them work. It is posted at least once on the forum....somewhere....
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
Re: parts?
I found this
Public Service Announcement - For future reference, the vibration dampening mounts for the instrument cluster have an M4x.70 thread with each thread section being 3/8" long and the rubber section 3/8" in diameter and 3/8" in length. I surfed through McMaster-Carr's catalog and the M4x0.7 with the same sized rubber or neoprene section but 1/2" threaded sections are Part #9376K111 and $1.50 each. This means that you can buy this part MUCH cheaper than the OEM, but you will have to cut 1/8" off of the threaded section that will go into the instrument cluster so you don't break the housing (it is a blind hole). I hope this helps save someone a few bucks in the future.
and this
Try the following website: http://www.mcmaster.com. It's the web site for McMaster-Carr, distributors of a variety of hardware and equipment, who will sell to individuals directly.
The item you want is Part Number 9376K112. It is a Vibration Damping Mount, with metric threads M4x0.7, 1/2" tall by 5/8" in diameter, at $1.66 each. They are just a little larger than the originals, but they work just fine. There are also the same item in a slightly smaller size, 3/8" x 3/8", with the same thread, if you prefer. I didn't write down the part number, but you will see it on the web catalog page just above the part number I provided.
I found my own in a store for motocross equipment.
The center stand springs btw are not available by Ducati any longer.
