The new stop ring is much easier to position and to remove again.
Note that as the new stop ring is thicker the groove also needs to be shifted slightly outwards as otherwise the ring won`t fit if the seals are mounted. (Be very careful doing this! Once ruined there`s no way back)
Of course you can also leave the fork as is and grind down the new stop ring to 1mm thickness.
