Spare parts catalogue!
Post by Tamburinifan »
For 907IE 1992 now avaliable as PDF at http://www.duc.nu/manuals . :D :cool: :thumbup:
OK quality.
Re: Spare parts catalogue!
http://forums.ducatipaso.org/viewtopic. ... 51&start=0
here you can find it for free. (in really good quality :)
I never understood how to open those bat-files.
there are 5 files, just download them and then doubleclick the .bat file.
The file was too big to upload so I had to slice it. Doubleclicking the .bat file will reconstruct all files to the original pdf. Just retried it myself. Works fine.
However, the site is quite cheap :thumbup:
OK, Gerhard.
Downloaded 1 file w MS.
MS asked: Want to save or open?
When I said open, a PDF opened w/o problems. :)
When I closed that & tried to open again, a DOSwindow opened. :(
So, I`m no PCwizard, please help me open this .bat-file.
Am I missing something simple? :oops:
just click on one file, if the download window appears do not cick "open" but "download". Do this with every file of the parts manual.
When you have all files on your PC (in one directory of course ie your desktop) doubleclick the .bat file. That`s it. Out comes the pdf.
When you have the pdf you can delete the downloaded files on your PC.
OK, thx!
ducatideanna
Post by ducatideanna »
I'm new to this site. I'm a Paso fan, I don't currently own one but I do work on them from time to time & I would really like to access the info that someone was kind enought to load into a BAT(?) file, bur I am having trouble doing it. Has anyone else gotten this to work? I have downloaded all the files into their own folder but from there I'm making no progress. I'm no a PC whiz so any remedial help would be appreciated muchly!!!
TIA
DeAnna
Laddie907
Post by Laddie907 »
the instructions work OK. I have the manual and it's good quality.
download all the files into one folder.
select (double-click) the .bat file
It look like nothing happens but a .pdf file is created in the same folder.
This is the manual.
You need adobe acrobat to read the file.
You can delete the other files when you're finished.
That`s the mistake. As Laddie says all files have to be in the same folder.
ducatideanna
That's what I was meaning to write.... All files are in the same folder as each other. I made a new folder to put them in with nothing else in it. I was hoping it would help, but it didn't. I'm still stuck.
DeAnna
englishstiv
Post by englishstiv »
Hi there mate this is how I did it and I have done this with Windows XP and Now with Vista.
Download each file individually
Then make a new Folder.
Put all four items into the new Folder
Click on the Batch Folder.
This will now unzip the files and you will have a new file created.
This is your manual name it as such if you haven't already
You can now delete the rest.
Click on the File and you will go to the Acrobat File click again and you will open and be able to read and print etc.
If you haven't got Adobe Acrobat you will need to instal the free version prior to this set up purpose.
Hope this helps.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
lhoward
Post by lhoward »
Anyway I can get the manuals in a non .bat file format? I MAC does not like them.
