clutch disaster
- year: 0
clutch disaster
I just got the paso back on the road but the clutchpack I was sold was for a 998b 900ss/0 so I very nearlysiezed the bike at first It rode fine but the master cylinder was leaking It through me off course with my thinking so I replaced it thinking Id be successful but after two days clutch went again which 750ss model has the same clutchpack must be the early ones also there was an old suzuki I think. ta desmo.
Re: clutch disaster
When i renewed the clutch plates on my 750 Paso the pack that i got given by the dealer was # 19020051A and cost £71.68p i fitted them and no problems as yet, clutch works ok.
Dave.
Dave.
- year: 0
Re: clutch disaster
got your reply dave eight of each yeah ive had 6 of each in mine wonder if basket is different did you put all 8 of each in yours is there anything ive missed i arranged steel one as a clock.what is the punched hole on the clutch centre for do you align this your reply said you had no drive because of the large circlip cant believe that! but that is how mine is now which went in first friction or steel. mine will only engage with a steel 1st friction last. (cheers desmodave. squires cafe regular.castleford.DaveM wrote:When i renewed the clutch plates on my 750 Paso the pack that i got given by the dealer was # 19020051A and cost £71.68p i fitted them and no problems as yet, clutch works ok.
Dave.
- year: 0
Re: clutch disaster
desmodave wrote:got your reply dave eight of each yeah ive had 6 of each in mine wonder if basket is different did you put all 8 of each in yours is there anything ive missed i arranged steel one as a clock.what is the punched hole on the clutch centre for do you align this your reply said you had no drive because of the large circlip cant believe that! but that is how mine is now which went in first friction or steel. mine will only engage with a steel 1st friction last. (cheers desmodave. squires cafe regular.castleford.DaveM wrote:When i renewed the clutch plates on my 750 Paso the pack that i got given by the dealer was # 19020051A and cost £71.68p i fitted them and no problems as yet, clutch works ok.
Dave.
